Captain Marc a écrit:En fait, le gourou aéro Mike Busch, considère que plus est mieux:
My recommendation is to use either Aeroshell W100 single-grade or Phillips X/C 20W-50 multigrade and to add at least 5% ASL Camguard (1 pint per 10 quarts) at each oil change. (A little extra Camguard doesn’t hurt, and a 10% concentration is recommended as a “pickling oil” if the aircraft will be idle for a significant length of time.) For our Savvy clients, we recommend W100 with Camguard as our first choice unless the airplane is likely to encounter unpreheated cold-starts in sub-freezing OATs, in which case we recommend Phillips 20W-50 with Camguard.
We have several Cirrus clients who had lousy looking oil analysis reports and cleaned up nicely after a couple of oil changes with Camguard. I have seen the same thing occur in at least a dozen engines in non-Cirrus aircraft (Bonanzas, Centurions and twin Cessnas) as well. I have documented my own oil analysis results from my own airplane in considerable detail in several aviation magazines. I am personally persuaded that the stuff works quite well and has no adverse side effects. (If I wasn’t , I sure wouldn’t be using it in my own engines, which are now approaching 200% of TBO.) I used Camguard quietly for almost two years before I started talking about it in public, because I was skeptical and wanted to see plenty of data before putting my reputation on the line.
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 331 invités
