Tontonlyco a écrit:Les premiers B707 et Caravelle étaient à moteurs simple flux, très bruyants, puis apparru le B747, qui décollait en silence.
Dans les dernières versions, des moteurs double flux furent-ils montés sur 707 et Caravelle ?
Wikipedia a écrit:707-700
The 707-700 was a test aircraft used to study the feasibility of using CFM International CFM56 engines on a 707 airframe and possibly retrofitting existing aircraft with the engine. After testing in 1979, N707QT, the last commercial 707 airframe, was restored to 707-320C configuration and delivered to the Moroccan Air Force as a tanker aircraft via a "civilian" order. Boeing abandoned the retrofit program, since it felt it would be a threat to the Boeing 757 program. The information gathered from testing led to the eventual retrofitting of CFM56 engines to the USAF C-135/KC-135R models, and some military versions of the 707 also used the CFM56. The Douglas DC-8 "Super 70" series with CFM56 engines was developed and extended the DC-8's life in a stricter noise regulatory environment. So, more DC-8s than 707s are in service now.
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 416 invités
