Gaffozelis a écrit:Via Editerra, cela mettra peut être 2 jours de plus pour lui arriver.
Gaffozelis a écrit:Lui faire un mail sur
jean.bossy @ wanadoo.fr
Projection = Lambert_Conformal_Conic
Datum = WGE
origin_latitude = N47 00 00
central_meridian = E002 00 00
std_parallel_1 = N45 00 00
std_parallel_2 = N49 00 00
false_Easting = 0
false_Northing = 0
OziExplorer Map Data File Version 2.2
Bossyfrance.ecw
E:\Documents\Aviation\MAPS\Bossy2010\CartaBossy 2010\bossyfrance.ecw
1 ,Map Code,
WGS 84,WGS 84, 0.0000, 0.0000,WGS 84
Reserved 1
Reserved 2
Magnetic Variation,,,E
Map Projection,Lambert Conformal Conic,PolyCal,No,AutoCalOnly,No,BSBUseWPX,No
Point01,xy, 2548, 1293,in, deg, 50, 0,N, 1, 0,W, grid, , , ,N
Point02,xy, 7458, 7349,in, deg, 43, 0,N, 7, 0,E, grid, , , ,N
Point03,xy, 7067, 1236,in, deg, 50, 0,N, 07, 0,E, grid, , , ,N
Point04,xy, 2315, 7415,in, deg, 43, 0,N, 1, 0,W, grid, , , ,N
Point05,xy, , ,in, deg, , ,N, , ,E, grid, , , ,N
Point06,xy, , ,in, deg, , ,N, , ,E, grid, , , ,N
Point07,xy, , ,in, deg, , ,N, , ,E, grid, , , ,N
Point08,xy, , ,in, deg, , ,N, , ,E, grid, , , ,N
Point09,xy, , ,in, deg, , ,N, , ,E, grid, , , ,N
Point10,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point11,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point12,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point13,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point14,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point15,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point16,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point17,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point18,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point19,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point20,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point21,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point22,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point23,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point24,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point25,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point26,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point27,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point28,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point29,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point30,xy, , ,in, deg, , ,, , ,, grid, , , ,
Projection Setup, 47.000000000, 2.000000000,,,, 49.000000000, 45.000000000,,,
Map Feature = MF ; Map Comment = MC These follow if they exist
Track File = TF These follow if they exist
Moving Map Parameters = MM? These follow if they exist
MM0,Yes
MMPNUM,4
MMPXY,1,0,0
MMPXY,2,9567,0
MMPXY,3,9567,8031
MMPXY,4,0,8031
MMPLL,1, -5.715830, 51.273165
MMPLL,2, 11.663721, 51.137125
MMPLL,3, 10.150674, 42.023246
MMPLL,4, -4.507407, 42.137849
MM1B,126.995735
LL Grid Setup
LLGRID,Yes,1 Deg,No,255,16711680,0,1 Deg,0,16777215,7,1,Yes,x
Other Grid Setup
GRGRID,No,No Grid,Yes,255,16711680,No Labels,0,16777215,8,1,Yes,No,No,x
MOP,Map Open Position,0,0
IWH,Map Image Width/Height,9567,8031
Utilisateurs parcourant ce forum: Philippe PONS et 413 invités
