Low temperature NOTE
When operating at low temperatures, installation of an oil thermostat, parallel to the oil cooler is highly recommended.
Advantages of oil thermostat:
• safe oil pressure after cold start,
• prevention of fuel and water accumulation in the oil
See the Service Letter SL-912 i-002 “Use of an oil thermostat”, current issue.
2.2) Minimum requirements for the oil thermostat
- Minimum inside diameter of the hose connection nipples: 9 mm
- Do not use angled hose connection nipples
- The pressure loss because of the flow resistance in the thermostat must not be more than 0.05 bar.
- Opening temperature must be between 82 °C and 90 °C
- Made fully of metal
Utilisateurs parcourant ce forum: Anthony PNL, bellerive03, cda, turquetil et 131 invités
